Line 11 , Section *PART* D11 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers. Line 12 , Section *PART* D15 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers. Line 13 , Section *PART* D17 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers. Line 14 , Section *PART* D20 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers. Line 15 , Section *PART* D21 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers. Line 16 , Section *PART* D22 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers. Line 17 , Section *PART* D25 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers. Line 18 , Section *PART* D26 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers. Line 19 , Section *PART* D3 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers. Line 20 , Section *PART* D4 1N58XX@TVS-2 * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "TVS-2". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
