查看: 1441|回复: 9
没有D码的文件可以调出来吗?
发表于 2008-8-12 16:26:00 | 显示全部楼层 |阅读模式
现经常有些客户的文件,(特别是小日本)的文件用CAM350调出来总是没有D码.
也查看不到D码,否则还可以手工输入.
但是我们发给一个培圳机构,他们可以做出来.
他说是用GENESIS2000做的.
现刚装了一个GENESIS2000,但是还不能正确调出来.
望大侠们指点几下.谢谢!
发表于 2008-8-13 00:54:00 | 显示全部楼层
传上\试一下
 楼主| 发表于 2008-8-14 15:39:00 | 显示全部楼层
[原创]
太太谢谢你了,资料已经上传.
 楼主| 发表于 2008-8-14 15:40:00 | 显示全部楼层
回复:(hhsacam350)[原创]
再传.谢谢!也请大家都试一下这个文件,看能否正确读入.
注:龙岗坪山的一个培训机构曾做好了这个文件,只是我不知道是怎么做的.想大家都互相学习.
谁知道的要教一下啊1
[此贴子已经被作者于2008-8-14 15:44:15编辑过]
发表于 2008-8-14 17:15:00 | 显示全部楼层
他们应该是对文件手工处理了,用genesis直接应该是读不进去的
发表于 2008-8-16 19:05:00 | 显示全部楼层
G04  Aperture Descriptions*
G04  D010 EL X5.0mil Y5.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X5.0mil Y5.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D011 EL X10.0mil Y10.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X10.0mil Y10.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D012 EL X12.0mil Y12.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X12.0mil Y12.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D013 EL X120.0mil Y120.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X120.0mil Y120.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D014 EL X15.0mil Y15.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X15.0mil Y15.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D015 EL X150.0mil Y150.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X150.0mil Y150.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D016 EL X25.0mil Y25.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X25.0mil Y25.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D017 EL X30.0mil Y30.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X30.0mil Y30.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D018 EL X35.0mil Y35.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X35.0mil Y35.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D019 EL X50.0mil Y50.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X50.0mil Y50.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D020 EL X75.0mil Y75.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X75.0mil Y75.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D021 EL X8.0mil Y8.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X8.0mil Y8.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D022 EL X80.0mil Y80.0mil H0.0mil 0.0deg (0.0mil,0.0mil) DR*
G04  "Ellipse X80.0mil Y80.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Draw"*
G04  D023 EL X100.0mil Y100.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X100.0mil Y100.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D024 EL X105.0mil Y105.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X105.0mil Y105.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D025 EL X115.0mil Y115.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X115.0mil Y115.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D026 EL X120.0mil Y120.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X120.0mil Y120.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D027 EL X135.0mil Y135.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X135.0mil Y135.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D028 EL X150.0mil Y150.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X150.0mil Y150.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D029 EL X165.0mil Y165.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X165.0mil Y165.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D030 EL X172.5mil Y172.5mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X172.5mil Y172.5mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D031 EL X70.0mil Y70.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X70.0mil Y70.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D032 EL X80.0mil Y80.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X80.0mil Y80.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D033 EL X85.0mil Y85.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X85.0mil Y85.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D034 EL X90.0mil Y90.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X90.0mil Y90.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D035 EL X95.0mil Y95.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Ellipse X95.0mil Y95.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D036 MH X157.5mil Y157.5mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Mounting Hole X157.5mil Y157.5mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D037 OV X75.0mil Y100.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Oval X75.0mil Y100.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D038 OV X100.0mil Y75.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Oval X100.0mil Y75.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D039 OV X90.0mil Y115.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Oval X90.0mil Y115.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D040 OV X115.0mil Y90.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Oval X115.0mil Y90.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D041 RR X130.0mil Y130.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Rounded Rectangle X130.0mil Y130.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D042 RR X145.0mil Y145.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Rounded Rectangle X145.0mil Y145.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D043 SQ X70.0mil Y70.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Rectangle X70.0mil Y70.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
G04  D044 SQ X85.0mil Y85.0mil H0.0mil 0.0deg (0.0mil,0.0mil) FL*
G04  "Rectangle X85.0mil Y85.0mil H0.0mil 0.0deg (0.0mil,0.0mil) Flash"*
这就是D码啊,没有D码就可以读的文件是POLYGON的,但是不同的软件读结果会不相同,不建议使用!
发表于 2008-8-16 19:07:00 | 显示全部楼层
你把这文件单独保存后用GENESIS配D码进去就可以了!
 楼主| 发表于 2008-8-19 11:00:00 | 显示全部楼层
回复:(lidaji)你把这文件单独保存后用GENESIS配D码...
谢谢了!
虽然我仍然不知如何处理.也要再次谢谢大家的支持.
有了大家的支持,我们才有继续提问的勇气.
其实我一点都不懂GENESIS2000,我是才刚装好的软件.自已在自学.真难啊!恐怕是学不出了.
我正想跳槽,在这个死厂做了几年主管,工资就是涨不上来.真不想再这样混下去了.
大家有好的介绍吗?
谢谢!
[此贴子已经被作者于2008-8-19 11:04:10编辑过]
发表于 2008-8-25 23:26:00 | 显示全部楼层
v2000行
发表于 2008-10-21 15:04:00 | 显示全部楼层
像这样的文件用GC-CAM读完全没问题。。。。。。。。。
GMT+8, 2024-9-27 23:34 , Processed in 0.228571 second(s), 20 queries .
