查看: 3445|回复: 25
有学习脚本的朋友请进
发表于 2007-5-20 10:19:00 | 显示全部楼层 |阅读模式
各位客户:
                    欢迎光临。会脚本,有脚本学习资料的朋友,帮帮兄弟门。老是把脚本当作RMB来交易太没有意思了,好东西大家一起分享,乐趣是最宝贵的。其他的兄弟意下如何。赞成的也不用鼓掌,不喜欢看的兄弟也不要砸鸡蛋。哈哈。
发表于 2007-5-20 22:28:00 | 显示全部楼层
#File name : Copy layers
#Purpose: Copy layers from cad or net to cam,in order to compare cam to cad or net.
#Written by: wjw
#Date: 6/10/2005
source $GENESIS_DIR/sys/scripts/common.csh
DO_INFO -t matrix -e $JOB/matrix -d ROW
DO_INFO -t step -e $JOB/$STEP -d SR_LIMITS
DO_INFO -t step -e $JOB/$STEP -d PROF_LIMITS
# Define correct temp. dir. depending on env. vars.
if ($?GENESIS_TMP) then
 set TMP = $GENESIS_TMP
else if ($?GENESIS_DIR) then
 set TMP = $GENESIS_DIR/tmp
else
 set TMP = /genesis/tmp
endif
# Set up gui data and response files
set GUI_DATA = $TMP/gui_data.$$
set GUI_RESP = $TMP/gui_resp.$$
# Set varible to use to point to drill size selection program and table (typically $GENESIS_DIR/sys/hooks).
set DTM_PATH = `echo "$GENESIS_DIR/sys/hooks"`
# Set control variable to select use of external drill table.
set NO_DRILL_TABLE = `echo "no"`
# Set control variable to select use of correct metric return.
set PROPER_METRIC = `echo "no"`
# Detect current operating system.
set CURR_OS = `uname -s`
# If current operating system is NT, set alias to call awk95 as "awk".
if ($CURR_OS == "WINDOWS_NT") then
 alias awk '$GENESIS_DIR/e${GENESIS_VER}/nt/bin/awk95'
endif
again:
set aquamarine = 409980
set pink = 997580
set tan = 827155
set gold = 998400
set light_blue = 688590
set grey = 757575
set yellow = 999900
set black = 000000
set white = 999999
#Define GUI window
again:
echo  WIN 300 200  >> $GUI_DATA
echo  FONT cbi18 >> $GUI_DATA
echo  FG $black  >> $GUI_DATA
echo  BG $white  >> $GUI_DATA
echo  FORM  >> $GUI_DATA
echo  LABEL "Copy or compare">> $GUI_DATA
echo  ENDFORM  >> $GUI_DATA
echo  BG 008800  >> $GUI_DATA
echo RADIO radio Copy H 1 890000 >> $GUI_DATA
echo Compare cad >> $GUI_DATA
echo cad to cam >> $GUI_DATA
echo net to cam >> $GUI_DATA
echo Delete >> $GUI_DATA
echo Exit >> $GUI_DATA
echo END >> $GUI_DATA
echo  BG 964650  >> $GUI_DATA
echo  CLABEL Softbridge Continue! >> $GUI_DATA
gui $GUI_DATA > $GUI_RESP
source $GUI_RESP; \rm $GUI_RESP; \rm $GUI_DATA
if ( $radio == 1 ) then
 ###限定在cad中运行
       if ($step == cad) then
       else
       PAUSE Error The current step is not CAD ,please run the scrip in CAD step!
       exit
       endif
   COM open_entity,job=$job,type=step,name=cad,iconic=no
   AUX set_group,group=$COMANS
set first_board_layer = 0
set second_layer = 0
set rout_layer = 0
set matrix_counter = 1
set current_layer = 0
set max_layer = 0
set max_layer = $#gROWcontext
         ###判断最高层
          while ( $matrix_counter <= $#gROWcontext )
            if ( $gROWname[$matrix_counter] == "rout" ) then
            set rout_layer = $matrix_counter
             @ rout_layer--
            endif
            if ( $gROWname[$matrix_counter] == "" ) then
            set max_layer = $matrix_counter
             @ max_layer--
            goto next
            endif
          @ matrix_counter++
          end
next:
##判断第一层
set matrix_counter = 0
      if ($gROWcontext[$matrix_counter] == "board") then
      set first_board_layer = $matrix_counter
      if ($first_board_layer > 2 ) then
      goto continue
      else
      PAUSE Error Please reading the origin file in cad step!
      exit
      endif
      endif
   @ matrix_counter++
end
continue:
#将非board属性的层排到最后
set matrix_counter = $first_board_layer
while ( $matrix_counter <= $rout_layer )
      if ($gROWcontext[$matrix_counter] == "misc") then
         COM display_layer,name=$gROWname[$matrix_counter],display=yes,number=1
         COM work_layer,name=$gROWname[$matrix_counter]
      COM sel_move_other,target_layer=$gROWname[$matrix_counter]_tmp,invert=no,dx=0,dy=0,size=0
      COM delete_layer,layer=$gROWname[$matrix_counter]
      COM rename_layer,name=$gROWname[$matrix_counter]_tmp,new_name=$gROWname[$matrix_counter]
      endif
   @ matrix_counter++
end
next2:
while ( $matrix_counter <= $first_board_layer )
set second_layer = `echo "scale=0;$matrix_counter + $first_board_layer - 1 "|bc`
if ($second_layer > $max_layer ) then
      PAUSE Error Please delete the additional layer ,then compare again!
      exit
endif
   @ matrix_counter++
end
###层比较
while ( $matrix_counter < $first_board_layer )
         COM display_layer,name=$gROWname[$second_layer],display=yes,number=1
         COM work_layer,name=$gROWname[$second_layer]
COM filter_area_strt
COM filter_area_end,layer=,filter_name=popup,operation=select,area_type=none,inside_area=no,intersect_area=no,lines_only=no,ovals_only=no,min_len=0,max_len=0,min_angle=0,max_angle=0
COM filter_reset,filter_name=popup
  COM get_select_count
  if ($COMANS == 0) then
              goto next1
              else
              COM clear_highlight
              COM sel_clear_feat
              COM compare_layers,layer1=$gROWname[$matrix_counter],job2=$job,step2=cad,layer2=$gROWname[$second_layer],layer2_ext=,tol=0.5,area=global,ignore_attr=,map_layer=$gROWname[$second_layer]_diff,map_layer_res=200
              COM display_layer,name=$gROWname[$second_layer]_diff,display=yes,number=1
              COM work_layer,name=$gROWname[$second_layer]_diff
              COM filter_set,filter_name=popup,update_popup=no,include_syms=r0
              COM delete_layer,layer=$gROWname[$second_layer]_diff
                        endif
              COM clear_highlight
              COM sel_clear_feat
              endif
next1:
   @ matrix_counter++
end
endif
if ( $radio == 2 ) then
if ($step == cam) then
       else
PAUSE Error The current step is not CAM ,please run the scrip in CAM step!
exit
endif
       if ( ( $gROWlayer_type[$matrix_counter] == "signal" || $gROWlayer_type[$matrix_counter] == "silk_screen" || $gROWlayer_type[$matrix_counter] == "solder_mask" || $gROWlayer_type[$matrix_counter] == "drill" || $gROWlayer_type[$matrix_counter] == "power_ground" ) && $gROWcontext[$matrix_counter] == "board" && $gROWname[$matrix_counter] != cs1 && $gROWname[$matrix_counter] != ss1  ) then
           COM copy_layer,source_job=$JOB,source_step=cad,source_layer=$gROWname[$matrix_counter],dest=layer_name,dest_layer=$gROWname[$matrix_counter]_cad,mode=replace,invert=no
       endif
   @ matrix_counter++
end
endif
if ( $radio == 3 ) then
       else
exit
endif
           COM copy_layer,source_job=$JOB,source_step=net,source_layer=$gROWname[$matrix_counter],dest=layer_name,dest_layer=$gROWname[$matrix_counter]_net,mode=replace,invert=no
       endif
   @ matrix_counter++
end
endif
if ( $radio == 4 ) then
foreach LAYER ($gROWname)
 set TST = `echo "$LAYER" | grep -c _cad`
 if ($TST != 0) then
  COM delete_layer,layer=$LAYER
 endif
end
 set TST = `echo "$LAYER" | grep -c _net`
 if ($TST != 0) then
 endif
end
 set TST = `echo "$LAYER" | grep -c _diff`
 if ($TST != 0) then
 endif
end
endif
if ( $radio == 5 ) then
exit
endif
发表于 2007-5-21 11:43:00 | 显示全部楼层
是的,我同意你的说话!
发表于 2007-5-25 11:55:00 | 显示全部楼层
同意,请问想学的话该从何下手
发表于 2007-6-30 21:30:00 | 显示全部楼层
dddddd.我顶!
发表于 2007-7-1 14:03:00 | 显示全部楼层
我也同意思,可这年代,能有几个会这样想呢?人都是很现实,都是在为了钱而活着。哎:悲哀!
发表于 2007-7-1 22:36:00 | 显示全部楼层
cs_cs   你的QQ多少是
  有时间跟你学习学习
发表于 2007-7-2 09:26:00 | 显示全部楼层
我真的费了很多力气来学这个,可是,不知道从什么地方入手,麻烦大的很
发表于 2007-7-6 20:02:00 | 显示全部楼层
要从哪个地方开始入手学啊.
发表于 2007-7-15 09:43:00 | 显示全部楼层
说的好啊
GMT+8, 2024-9-27 17:31 , Processed in 0.178668 second(s), 19 queries .
