转化过程中出现下面的问题,而且丢了一些元件,是什么原因造成的? Load Errors : 299
Error loading label visibility attribute from line: 1749
Expected number in line: 1750 at position 0 and found this: **CRLF**
Expected integer in line: 1750 at position 0
Error loading label mirrored attribute from line: 1750
Error loading label text justification attributes from line: 1750
Error loading label right-reading attribute from line: 1750
Error loading label visibility attribute from line: 1751
Expected number in line: 1751 at position 5 and found this: Type
Expected number in line: 1752 at position 0 and found this: **CRLF**
Expected integer in line: 1752 at position 0
Error loading label mirrored attribute from line: 1752
Error loading label text justification attributes from line: 1752
Error loading label right-reading attribute from line: 1752
Expected number in line: 1753 at position 0 and found this: Ref.Des.
Expected number in line: 1754 at position 0 and found this: **CRLF**
Invalid pin data discarded.
'PAD' expected in line: 1761
Expected integer in line: 1761 at position 0
Expected integer in line: 1762 at position 0
Bad pad stack data in line: 1762.
Can't load pad stack. |
