Load Warnings : 15
Error loading via mode global setting, using 'through' via as default.
Error in line: 109.
Nothing to load, empty line!
The smallest available values for diameter and hole size will be taken for via: JMPVIA_AAAAA
Via padstack is unsupported.
The smallest available values for diameter and hole size will be taken for via: XU-2516
Error in line: 1749.
Error in line: 3465.
Error in line: 3722.
Error in line: 4520.
Nothing to load, empty line! Import Warnings : 18
WARNING: Pad without through board connectivity imported: J501.1.
WARNING: Pad without through board connectivity imported: J501.2.
WARNING: Pad without through board connectivity imported: J501.3.
WARNING: Pad without through board connectivity imported: J501.4.
WARNING: Pad without through board connectivity imported: J501.5.
WARNING: Pad without through board connectivity imported: J503.1.
WARNING: Pad without through board connectivity imported: J503.2.
WARNING: Pad without through board connectivity imported: J503.3.
WARNING: Pad without through board connectivity imported: J503.4.
WARNING: Pad without through board connectivity imported: J503.5.
WARNING: Zero sized pad imported: U401.45.
WARNING: Zero sized pad imported: U401.46.
WARNING: Zero sized pad imported: X201.3.
WARNING: Zero sized pad imported: X201.4.
WARNING: Zero sized pad imported: X201.5.
WARNING: Zero sized pad imported: X401.3.
WARNING: Zero sized pad imported: X401.4.
WARNING: Zero sized pad imported: X401.5.
