- 5612
楼主 |
发表于 2010-5-25 18:27:59
显示全部楼层
回复 157# hnzzlyg
一个PCB相关的计算器,推荐给大家,包括特征阻抗计算、过孔导线温升载流计算等,温升的计算采用最近的IPC2152标准。
Program includes:
PCB Via Current Calculator per IPC-2152
Calculates the current a via needs to raise its temperature over ambient per IPC-2152.
Other via properties include:
Via capacitance
Via inductance
Via impedance
Via step response
Via DC resistance
Via impedance
Via resonant frequency
PCB Trace Width Calculator & PCB Trace Resistance Calculator per IPC-2152
Calculates the current a conductor needs to raise its temperature over ambient
per IPC-2152. Now also calculates DC resistance with temperature compensation.
Other conductor properties include:
Conductor skin depth
Conductor voltage drop
Conductor DC resistance
Conductor power dissipation
Bandwidth Calculator & Max PCB Trace Length Calculator
Calculates the bandwidth of a digital signal and maximum trace length, using the IPC-2251 method or the
frequency domain method, for transmission line effects.
Wavelength calculator for given frequency.
Differential Pair Impedance Calculator
Calculates the differential pair impedance of a balanced line.
PCB Padstack Calculator
Calculates the outer and inner layer diameters of a padstack given the drill size.
BGA land calculator based on the IPC-7351A specification.
Mechanical Data
Calculates wire diameter for a given AWG gauge.
Drill chart with imperial and metric diameters.
Imperial screw thread size chart.
Minimum PCB Conductor Spacing Chart
Calculates minimum conductor spacing's using peak AC or DC voltage based on IPC-2221A data.
PCB conductor Impedances
Calculates impedance of a PCB Microstrip or PCB Stripline.
Inductance of a microstrip
Capacitance of a microstrip
Propagation delay of a microstrip
Units Conversion Data
Converts mm to mils and C to F.
Embedded units chart for reference.
Planar Inductor Calculator
Calculates the inductance of a planar PCB spiral inductor.
Power Delivery System Impedance Calculator
Calculates the target impedance of a PDN.
Thermal Resistance Calculator
Calculates the junction temperature of a device using thermal resistance.
下载链接:
http://saturnpcb.com/Saturn%20PCB%20Toolkit%20V5.0%20Setup.zip
