Batch Router Statistics Pre-routing analysis in progress... Can't exit from pin(s) U14.33, U14.30, U14.35, U1.U6, U1.U6 with mimimum width because of large clearance values. To correct the problem, use the Design Rules dialog box in PADS Layout or the Routing tab of the Design (or Net or Component) Properties dialog box in PADS Router. Pins C176.1, U1.A1, U1.A1, U1.A6, U1.A1, U1.A2, U6.F3, U1.A2, U1.A3, U1.B1, U1.A4, U1.A3, U1.A3, U1.A4, U1.A3, U1.A5, U1.A4, U1.A4, X2.2, U1.A4, U1.A5, U1.A4, U1.A7, U1.A5, U1.A5, C51.1, U1.A6, U1.A1, U1.A6, U1.A6, U1.A10, U1.A6, U1.A7, U1.A5, U1.A7, U1.A8, U7.H1, U1.A8, U1.A9, C18.1, U1.A9, C6.1, U1.A10, U1.A6, U1.A10, U1.A10, U1.B11, U1.A10, U1.A11, U1.B10, U1.A12, U1.A11, U1.A11, X2.2, U1.A11, U1.A12, U1.A11, U1.B13, U1.A12, U1.A12, U1.A13, RP4.1, U1.A13, U1.A14, RP3.1, U1.A14, U1.C17, U1.A15, U1.A15, X2.2, U1.A15, U1.A16, C4.1, C5.1, U1.A16, U1.A16, U1.F16, U1.A16, U6.D1, U1.A17, U1.A17, U1.A3, U1.B1, U1.B1, U1.B3, R9.2, U1.B3, U1.B4, R8.2, U1.B4, U1.B5, U6.F1, U1.B5, C16.1, U1.B6, U1.B6, U1.C1, U1.B6, U1.B7, U7.H7, U1.B7, U7.H2, U1.B8, U1.B8, U7.H9, U1.B9, U1.B9, U1.A11, U1.B10, U1.B10, U1.A10, U1.B11, U1.B11, C19.1, U1.B12, U1.B12, U1.H12, U1.B14, U1.B12, U1.B12, U1.B13, U1.A12, U1.B13, U1.B14, U1.B12, U1.B16, U1.B14, U1.B14, U6.D2, U1.B15, U1.B15, U1.B16, U1.B14, U1.B16, U6.A2, U1.B17, U1.B17, U1.C1, C13.1, U1.B6, U1.C1, U1.C1, U1.C4, U8.61, U1.C4, R1.1, U1.C5, U1.C5, U1.C6, U7.F8, U1.C6, U1.C7, U7.J8, U1.C7, U7.G3, U1.C8, U1.C8, U7.G7, U1.C11, U1.C11, ... are covered by board outline, trace(s) keepout(s), text(s) or copper(s). To correct the problem, use Move commands in PADS Layout or PADS Router. Pre-routing analysis finished. Done> Unroutes 1386 Routed 15 of 1401 (1.1%) Vias 0 Duration 00:00:11 |
