genesis新版本修正的错误 v8.2c7 Not released yet
kit 12733 ESI Drill Output - Step and Repeat Problem (Steven Welsh, Orbotech US) v8.2c6 30 May 2004
kit 12729 Moving one pad takes ages (Claudio Bellistri, Orbotech SA)
kit 12720 Edit Resize Dropping Clearance In A Surface (Ron Fisher, Merix)
kit 12691 Graphic Viewer errors (Dana Cang, Frontline) v8.2c5 12 May 2004
kit 12684 Netlist does not read in (James Amundson, Coretec)
kit 12677, 11868 Creating new split in ETM crashes Genesis (Enzo Subiaco, CST)
kit 12670 Wrong Contourize results depending on zoom (Jurgen Mehner, Polytron Print)
kit 12584 Construct pad removes trace (James Amundson, Coretec)
kit 12569 Decompose out problem (Sugii Tomokazu, System Advance)
kit 12423 Contour problem in OPFX output (Uri Sherf, Orbotech IL; Steve Eccles, Zlin) v8.2c4 1 Apr 2004
kit 12630 Internal error when output gerber Rs274x (Ken Fu, Kernel HK)
kit 12604 Signal Layer Optimizer Causes short (Russ Hotaling, Sanmina)
kit 12602 Filling of outer layers draws over PCB area (Peter Eberz, Wurth)
kit 12595 Missing Entities (Ron Fisher, Merix)
kit 12554 Surface ouput to plotter (Ken Fu, Multek)
kit 12545 Problem in create layers on checklist by Japanese (Miyazaki Masato, Orbotech Japan)
kit 11930 Bad dpf input (Philippe Vanthuyne, Orbotech SA) v8.2c3 15 Mar 2004
kit 12597 Holes are removed when playing with vertex (Enzo Subiaco, CST)
kit 12594 Input job would internal error (Limey Wang, Unimicron)
kit 12580 Octagons are not read in correctly (Peter Eberz, Wurth)
kit 12578 Input Gerber 274X - Crashes Genesis (Nicholas Meeker, Tech Circuits)
kit 12566 Input DPF file would lost some data (Limey Wang, Cimax)
kit 12525 Symbol is rotated wrongly by Solio in (Miyazaki masato, Orbotech Japan)
no kit TrueColor performance enhancement v8.2c2 26 Feb 2004
kit 12251 Genesis crash when see report in Netlist Optimizer (Atipong Chookruwong, PCB Center)
kit 12549 Info command runs and does not end (Zvika Kopelovitch, Frontline)
kit 12544 Solder mask check (Yaron Snir, Eltek)
kit 12542 Close job give internal error (Atipong Chookruwong, KCE International)
kit 12527 Crash during output to Image (Josh Breitbach, Rockwellcollins)
kit 12503 The part of surface disappeared by RS274X out (Miyazaki masato, Maco)
kit 12502 BSL output (Norimatsu Takayoshi, Hitachi) v8.2c1 12 Feb 2004
kit 12537 Rs274x input crashes Genesis (Dana Cang, Frontline)
kit 12524 Input rs274x file decode not correct (Limey Wang, Orbotech Pacific)
kit 12523 Microcraft Adjacency problem (Ishvar Sutariya, Saturn Electronics)
kit 12521 Inconsistent arc changes to positive (Ken Fu, Orbotech Pacific)
kit 12513 Identification of Semi-standard symbols in Rs274x input (Miyazaki masato, Ibiden)
kit 12512 Camtek on Linux (Serge Bonenfant, Viasystems Canada)
kit 12511 Data loss after calculating netlist (Curt Schneider, Merix)
kit 12504 Wrong symbol output by HPGL out (Miyazaki masato, Maco)
kit 12462 Problems with ODB++ XML import (Saeed Shirazi, Graphic Electronics)
kit 12241 Detch give wrong Compensation (Gidon Elissar, Frontline)
kit 11997 Calculate slot length and width in DTM (Tim Chen, GCE)
kit 11196 Request to add slot information to drill map and drill tool manager (Youngbae Kim, Samsung)
kit 2595 Slot dimension (Wus) |
