谢谢LC提供了这么好的工具,可我在SPB16.01中不能调用所生成的封装,出现的提示如下: Opening existing drawing... Opening existing drawing... W- Dielectric layer thickness is 0 ! last pick: 30.00 10.00 No element found. Select elements to place using tree view. W- (SPMHUT-48): Scaled value has been rounded off. E- (SPMHA1-151): Symbol extents are greater than the drawing extents ... increase the drawing extents. W- (SPMHUT-48): Scaled value has been rounded off. E- (SPMHA1-151): Symbol extents are greater than the drawing extents ... increase the drawing extents. W- (SPMHUT-48): Scaled value has been rounded off. E- (SPMHA1-151): Symbol extents are greater than the drawing extents ... increase the drawing extents. last pick: 115.01 42.30 W- (SPMHUT-40): Pick is outside the extent of the drawing ... pick again. last pick: 176.67 23.17 W- (SPMHUT-40): Pick is outside the extent of the drawing ... pick again. last pick: 169.02 -8.29 W- (SPMHUT-40): Pick is outside the extent of the drawing ... pick again. last pick: 118.84 35.08 W- (SPMHUT-40): Pick is outside the extent of the drawing ... pick again. last pick: 146.05 52.51 W- (SPMHUT-40): Pick is outside the extent of the drawing ... pick again. Select elements to place using tree view. Opening existing drawing... Performing a partial database check before saving. Writing database to disk. 'TO228P970X238-3L.dra' saved to disk. Symbol 'to228p970x238-3l.psm' created. Opening existing drawing... W- Dielectric layer thickness is 0 ! Select elements to place using tree view. W- (SPMHUT-48): Scaled value has been rounded off. E- (SPMHA1-151): Symbol extents are greater than the drawing extents ... increase the drawing extents. W- (SPMHUT-48): Scaled value has been rounded off. E- (SPMHA1-151): Symbol extents are greater than the drawing extents ... increase the drawing extents. W- (SPMHUT-48): Scaled value has been rounded off. E- (SPMHA1-151): Symbol extents are greater than the drawing extents ... increase the drawing extents. W- (SPMHUT-48): Scaled value has been rounded off. E- (SPMHA1-151): Symbol extents are greater than the drawing extents ... increase the drawing extents. |
