- 1899
Genesis 2000 Version 9.1
| Major New Features - DFM & Analysis
- Gold Tiebar Creation - enables to automatically create a connection between the gold plated pads in the circuit to the gold tiebar that lies outside the profile.
- Galvanic Etch Compensation - Compensates copper pads over-etched in the acid bath due to galvanic corrosion. Enables enlarging specific pads in nets with gold plated pads, while preserving spacing specification.
- Graphic Editor
- Add Teardrop function enables the user to interactively create teardrops in special locations
- Automatic PCB Numbering enables the user to automatically add an index number to the different steps in the panel.
- Change Arc Radius allows the user to interactively change the radius of an existing arc
- Reroute Trace allows the user to interactively reroute a trace, while keeping horizontal, vertical or 45 degree line segments.
- Add a chamfered/rounded/oblong rectangular polyline enrich Genesis drawing capabilities by making it easier to draw complex outlines.
- Input
- Supports the input of bitmap (.bmp, .jpg/. jpeg, .gif, .tif/.tiff) formats.
- Output
- New Interface to Orbotech DI machines.
Major Enhancements - DFM & Analysis
- Editor
- S&R Fill Pattern - Consideration for specific features located on the PCB step but lying outside the PCB profile, which should be cleared by the fill in the panel
- Add & Change Text:
Support for multiple fonts Support for Chinese and Japanese input methods - Improved Space Tracks Evenly function
- A new Release/Restore Step dependency function allows you to perform certain operations in the Job Matrix even when a dependent step exists
- Snap to 45?angle for Pull Line
- Add line at any defined angle
- Electrical Testing
- Ability to Copy S&R table from Panel Step within the Netlist Optimizer and ETM
