请教各位高手: 我在公司用PADS2005SP3软件画的PCB,由于要打板,而做板的公司用的是POWER PCB5.0的版本.所以我从PADS2005SP3将PCB导出为ASC文件,版本为5.0.结果用POWER PCB5.0导入时,有如下的警告信息: Reading file -- E:\mtk(2)\40-TDM610-MAA2X.asc Drawing piece has wrong number of corners 1 in piece 0 OPEN 1 150000 0 *Bad lines piece data line format VALUE -750000 0 0.000 1 1800000 150000 N RIGHT DOWN REGULAR <ROMANSIM STROKE FONT> *Bad *PARTDECAL* ascii data line format REF.DES. drawing name already used VALUE VALUE 9750000 -3750000 0.000 1 1800000 150000 N CENTER DOWN *Bad *PARTDECAL* ascii data line format REGULAR <ROMANSIM STROKE FONT> *Bad *PARTDECAL* ascii data line format VALUE *Bad *PARTDECAL* ascii data line format T0 0 0 0 *Bad *PARTDECAL* ascii data line format T750000 0 750000 0 *Bad *PARTDECAL* ascii data line format T1500000 0 1500000 0 *Bad *PARTDECAL* ascii data line format T2250000 0 2250000 0 *Bad *PARTDECAL* ascii data line format T3000000 0 3000000 0 *Bad *PARTDECAL* ascii data line format T3750000 0 3750000 0 *Bad *PARTDECAL* ascii data line format T4500000 0 4500000 0 *Bad *PARTDECAL* ascii data line format T5250000 0 5250000 0 *Bad *PARTDECAL* ascii data line format T6000000 0 6000000 0 *Bad *PARTDECAL* ascii data line format T6750000 0 6750000 0 *Bad *PARTDECAL* ascii data line format T7500000 0 7500000 0 *Bad *PARTDECAL* ascii data line format T8250000 0 8250000 0 *Bad *PARTDECAL* ascii data line format T9000000 0 9000000 0 *Bad *PARTDECAL* ascii data line format T9750000 0 9750000 0 *Bad *PARTDECAL* ascii data line format T10500000 0 10500000 0 *Bad *PARTDECAL* ascii data line format T11250000 0 11250000 0 *Bad *PARTDECAL* ascii data line format T12000000 0 12000000 0 *Bad *PARTDECAL* ascii data line format T12750000 0 12750000 0 *Bad *PARTDECAL* ascii data line format T13500000 0 13500000 0 *Bad *PARTDECAL* ascii data line format T14250000 0 14250000 0 *Bad *PARTDECAL* ascii data line format T15000000 0 15000000 0 *Bad *PARTDECAL* ascii data line format T15750000 0 15750000 0 *Bad *PARTDECAL* ascii data line format T16500000 0 16500000 0 *Bad *PARTDECAL* ascii data line format T17250000 0 17250000 0 *Bad *PARTDECAL* ascii data line format T18000000 0 18000000 0 *Bad *PARTDECAL* ascii data line format PAD 0 3 Too many decimal places in number -2 450000 OF 90.000 1875000 0 0 *Bad *PARTDECAL* ascii data line format -1 0 R *Bad *PARTDECAL* ascii data line format 0 0 R *Bad *PARTDECAL* ascii data line format PAD 1 3 Too many decimal places in number -2 450000 RF 90.000 1875000 0 0 *Bad *PARTDECAL* ascii data line format -1 0 R *Bad *PARTDECAL* ascii data line format 0 0 R **INPUT WARNINGS FOUND** 不知那位能帮忙解决一下,不胜感激! 我知道可以给GERBER文挡.但问题出来了,总得解决啊, 帮帮忙,谢谢各位 |
