小弟公司目前用的是POWER 4.0.1的版本, 可是读不了5.0以上版本的文挡,转换成ASCII 文件后,导入出现如下的提示错误,不知怎么回事,还请高手帮帮忙啊. 不知是我导错的原因还是有其它打开的方法. Reading file -- D:\production\PWM\PWM CONTROL.asc *Unspecified or unsupported version of ASCII file !PADS-POWERPCB-V5.0-BASIC! DESIGN DATABASE ASCII FILE 1.0 *Bad *PCB* ascii data line FABCHKFLAGS 3967 FABRICATION CHECKS FLAGS *Bad *PCB* ascii data line ATMAXSIZE 114300 ACID TRAPS MAXIMUM SIZE *Bad *PCB* ascii data line ATMAXANGLE 161999820 ACID TRAPS MAXIMUM ANGLE *Bad *PCB* ascii data line SLMINCOPPER 114300 SLIVERS MINIMUM COPPER *Bad *PCB* ascii data line SLMINMASK 114300 SLIVERS MINIMUM MASK *Bad *PCB* ascii data line STMINCLEAR 5 STARVED THERMAL MINIMUM CLEARANCE *Bad *PCB* ascii data line STMINSPOKES 4 STARVED THERMAL MINIMUM SPOKES *Bad *PCB* ascii data line TPMINWIDTH 114300 MINIMUM TRACE WIDTH *Bad *PCB* ascii data line TPMINSIZE 114300 MIMIMUM PAD SIZE *Bad *PCB* ascii data line SSMINGAP 114300 SILK SCREEN OVER PADS MINIMUM GAP *Bad *PCB* ascii data line SBMINGAP 114300 SOLDER BRIDGES MINIMUM GAP *Bad *PCB* ascii data line SBLAYER 1 SOLDER BRIDGES LAYER *Bad *PCB* ascii data line ARPTOM 114300 PAD TO MASK ANNULAR RING *Bad *PCB* ascii data line ARPTOMLAYER 1 PAD TO MASK ANNULAR RING LAYER *Bad *PCB* ascii data line ARDTOM 114300 DRILL TO MASK ANNULAR RING *Bad *PCB* ascii data line ARDTOMLAYER 1 DRILL TO MASK ANNULAR RING LAYER *Bad *PCB* ascii data line ARDTOP 114300 DRILL TO PAD ANNULAR RING *Bad *PCB* ascii data line ARDTOPLAYER 0 DRILL TO PAD ANNULAR RING LAYER *Bad *PCB* ascii data line PLNSEPGAP 228600 PLANE SEPARATION GAP *Bad *PCB* ascii data line IDFSHAPELAY 0 IDF SHAPES LAYER Bad Lines item type name <BOARD> DRW46139319 BOARD -86850000 85200000 1 *Bad *LINES* ascii data line format CLOSED 5 381000 0 4 *Bad *LINES* ascii data line format 11850000 -10200000 2 *Bad *LINES* ascii data line format 161850000 -10200000 2 后面还有很多 |
