引自 http://www.gnovo.com/NewsInfo.asp?Id=12 Gnovo Technologies Ltd. 提供PCB设计的全面解决方案,敬请访问http://www.gnovo.com Mentor Graphics 2月20日宣布,PADS2007今天正式发布,用户可以在 http://www.mentor.com/SupportNet/ 上下载。
PADS2007主要注重了功能集成、易用性以及增加新功能和补丁,其新功能主要包括:
All PADS Products
--ECO Enhancements --Alphanumeric Pin Number Improvements --Part Type Editor Enhancements --File Locking --GUI Customization
PADS Logic
--ECO Enhancements – Rules Comparison --Dialogs, Menu Consolidation --Allow Single Attribute Editing in Attribute Label Properties Dialog --Launch Bus Properties Command from Bus Name Properties dialog --GUI Customization --38 defect fixes
PADS Layout/Router
--RF Design in PADS Layout including ------DXF Import in Decal Editor for RF Component Creation ------Via Array Enhancements (not just for RF design!) ------Artwork improvements for Copper Shapes - Square and ------Copper Creation ------Complex Solder Dams --DFF Audit Now Included in all PADS Layout Licenses --Solder Mask/Paste Mask Output CAM --Pin Number Visibility in PADS Layout/Router, Decal --Route Length Monitor in Bus Route Operation --Conversion of Drafting Objects to Board Cut Out --New Through/Partial Column in the Drill Chart --Modeless Commands for Switching Current Design Units --Differential Pair Routing Improvements --New Text Command and Uncombine Operation Improvement --Over 130 defect fixes
DxDesigner
--Alternate Decal Support --ECO Enhancements – Rules Comparison --DxDesigner to PADS Router Cross Probing --Added DxDesigner Link Tool as Primary Integration Tool --LineSim Integration with DxDesigner
DxSim
--DxSim is an addition to the DxDesigner family and provides an integrated, easy to use, analog simulation environment |
