以下是引用jcf_mei在2007-3-15 13:30:00的发言: 谢谢。可是下载不到。 注册用户才可以下。其实安装没必要一定在D盘。以下为最快捷方式。 1,在C:建立FLEXLM目录,里面放LICENSE。DAT文件。 2,修改powerlogic.ini,powerpcb.ini,pads2sp.ini文件里的路径为动态路径即可。例如powerpcb.ini的内容如下: [Graphics] DisableCaching=0 [Global_Preferences] RealtimeRedraw=0 [general] Editor=notepad.exe CursorType=5 [directories] SystemDir=..\Programs FileDir=..\pads-file\ UserDir=..\Settings LibDir=..\Libraries ReuseDir=..\Reuse CAMDir=..\Cam VBScriptDir=..\ [Logic_Family_List] LogFam1=ANA,U LogFam2=BGA,U LogFam3=BPF,U LogFam4=BQF,U LogFam5=CAP,C LogFam6=CFP,U LogFam7=CLC,U LogFam8=CMO,U LogFam9=CON,J LogFam10=CQF,U LogFam11=DIE,U LogFam12=DIO,D LogFam13=DIP,U LogFam14=ECL,U LogFam15=EDG,P LogFam16=FLP,U LogFam17=FUS,F LogFam18=HMO,U LogFam19=HOL,X LogFam20=IND,L LogFam21=LCC,U LogFam22=MOS,U LogFam23=OSC,Y LogFam24=PFP,U LogFam25=PGA,U LogFam26=PLC,U LogFam27=POT,P LogFam28=PQF,U LogFam29=PSO,U LogFam30=QFJ,U LogFam31=QFP,U LogFam32=QSO,U LogFam33=RES,R LogFam34=RLY,K LogFam35=SCR,SC LogFam36=SKT,U LogFam37=SOI,U LogFam38=SOJ,U LogFam39=SOP,U LogFam40=SSO,U LogFam41=SWI,S LogFam42=TQF,U LogFam43=TRX,Q LogFam44=TSO,U LogFam45=TTL,U LogFam46=VPN,V LogFam47=VSO,U LogFam48=XFR,T LogFam49=ZEN,Z [macros] LOGMode=0 LOGCompressionMode=1 EnableMacroLanguage=1 DetectDifferentResolution=0 VBScript1=..\Layout\00 - What is a Basic Script.bas|0 VBScript2=..\Layout\01 - Using a Message Box.bas|0 VBScript3=..\Layout\02 - Using a Variable.bas|0 VBScript4=..\Layout\03 - Using a Basic Function.bas|0 VBScript5=..\Layout\04 - Using a PADS Layout Function.bas|0 VBScript6=..\Layout\05 - Using If and Then Statements.bas|0 VBScript7=..\Layout\06 - Using a Custom Dialog1.bas|0 VBScript8=..\Layout\07 - Using a Custom Dialog2.bas|0 VBScript9=..\Layout\08 - Using a Custom Dialog3.bas|0 VBScript10=..\Layout\09 - Using it All Together.bas|0 VBScript11=..\Layout\10 - List Of Comps and Nets.bas|0 VBScript12=..\Layout\11 - Select by Pin Count.bas|0 VBScript13=..\Layout\12 - Move by Pin Count.bas|0 VBScript14=..\Layout\13 - Width Table.bas|0 VBScript15=..\Layout\14 - Off-grid Pins.bas|0 VBScript16=..\Layout\15 - Select All Test Points.bas|0 VBScript17=..\Layout\16 - Part Web Search.bas|0 VBScript18=..\Layout\17 - Excel Part List Report.bas|0 VBScript19=..\Layout\18 - Excel Pin List Report.bas|0 VBScript20=..\Layout\19 - Excel Via List Report.bas|0 VBScript21=..\Layout\20 - Excel Drill Report.bas|0 VBScript22=..\Layout\21 - Excel Drill Drawing.bas|0 VBScript23=..\Layout\22 - Excel Drill Drawing with Testpoints.bas|0 VBScript24=..\Layout\23 - Create Assembly Labels.bas|0 VBScript25=..\Layout\Alive Net List.bas|0 VBScript26=..\Layout\BGA Die Report.bas|0 VBScript27=..\Layout\BGA Export Die to CSV File.bas|0 VBScript28=..\Layout\BGA Wirebond Report.bas|0 VBScript29=..\Layout\PADS Layout Script Wizard.bas|0 ScriptCount=29 [Library_List] Lib3=common "..\Libraries" YNY [utilities] BlazeRouterMonitor=..\Programs\BlazeRouterMonitor.exe ? BoardSimExe=..\hyperlynx\BSW.EXE [Memory] UndoMemorySize=2 FlushUndoBeyondSize=2 [monitor] normal=10 norules=15 error=12 [Colormap] Color0=0 0 0 Color1=0 0 128 Color2=0 128 0 Color3=0 128 128 Color4=128 0 0 Color5=128 0 128 Color6=128 128 0 Color7=128 128 128 Color8=192 192 192 Color9=0 0 255 Color10=0 255 0 Color11=0 255 255 Color12=255 0 0 Color13=255 0 255 Color14=255 255 0 Color15=255 255 255 Color16=192 192 0 Color17=0 128 192 Color18=0 192 64 Color19=0 192 192 Color20=255 96 96 Color21=128 128 192 Color22=187 96 0 Color23=255 0 128 Color24=182 182 106 Color25=34 145 255 Color26=128 192 128 Color27=155 255 255 Color28=255 156 156 Color29=170 170 212 Color30=255 173 91 Color31=255 128 192 [main window] Maximized=1 Xpos=268 Ypos=87 Width=731 Height=609 [ViaShield] VS_StitchVoids=0 VS_IgnoreTracesInDRCOff=1 [dialogs] Selection Filter - Position=641 166 -1 -1 - Position=8 60 -1 -1 Display Colors Setup - Position=439 183 -1 -1 Status - Position=671 243 -1 -1 About PADS Layout... - Position=435 384 -1 -1 Library Manager - Position=427 45 -1 -1 Font Replacement - Position=389 109 -1 -1 Global - Position=415 101 -1 -1 Design - Position=415 99 -1 -1 Routing - Position=415 99 -1 -1 Thermals - Position=415 99 -1 -1 Dimensioning - Position=415 98 -1 -1 Teardrops - Position=415 99 -1 -1 Drafting - Position=415 98 -1 -1 Grids - Position=415 99 -1 -1 Split/Mixed Plane - Position=415 99 -1 -1 Die Component - Position=415 99 -1 -1 Via Patterns - Position=415 99 -1 -1 Object Attributes - Position=274 111 -1 -1 [Library_Filters] Library_Manager_Filter=* Library_Manager_Library=common Part_Type_Filter=* Part_Type_Library=common [OpenedFiles] File1= [Design_Preferences] Prompt_Net_For_Copper=1 DRC_mode=1 [DieComponentPreferences] OutlineLayer=0 CBPLayer=0 WBLayer=1 SBPGuidesLayer=2 SnapThreshold=381000
这样,随便把PADS2007放在哪都可以运行了。。。。。。。。。。。 |
