查看: 951|回复: 6
在PADS2007中找不到menufile.dat了,不知有没人知道怎么改快捷方式啊?
发表于 2007-3-15 18:49:00 | 显示全部楼层 |阅读模式
在PADS2007中找不到menufile.dat了,不知有没人知道怎么修改快捷键啊?以前都用了自己改的快捷键,现在不能改了很不习惯啊!
发表于 2007-3-16 09:10:00 | 显示全部楼层
对呀? 关注!
发表于 2007-3-16 09:33:00 | 显示全部楼层
2007中可以直接修改了,不用找文件
修改如下:
Creating a New Shortcut Key
You create shortcuts that apply in any mode. Thus, the same shortcut key may have different functionality depending on the mode in which you are working.
To create a shortcut key:
  1. Tools menu > Customize > Keyboard and Mouse tab.
  1. In the Mode box, select the mode to which you want to apply the shortcut. The available commands for that mode appear in the Commands box.
  1. In the Commands box, select the command for which you want to create a new shortcut. If a shortcut already exists, it appears in the Current shortcuts box.
Tip: To replace an existing shortcut, click Delete to remove the existing shortcut, and create a new shortcut for the command.
  1. Above the Current shortcuts box, click the New button to open the Assign shortcut dialog box.
  1. Select one of the following types of shortcut:
  • To assign shortcut keys, select Press new shortcut key(s), and then press the keys that you want to use. For detailed information about rules and restrictions for creating shortcut keys, see Rules and Restrictions for Key Sequences.
Tip: As you enter the new shortcut, similar shortcuts appear in the Similar shortcuts assigned to other commands box. This helps you to avoid creating a new shortcut that conflicts with an existing shortcut.
  • To create a mouse action, select or select a pointer event, and then select a combination of list box options, mouse button events, and modifier keys.
  1. Click OK to close the Assign shortcut dialog box.
Result: The new shortcut appears in the Current shortcuts box on the Customize dialog box
 楼主| 发表于 2007-3-16 14:27:00 | 显示全部楼层
终于会改了,谢谢3楼。只是找要改的项很不方便,不象以前那样可以查找到要改的项改,现在得一个个找过去,我想把返回的快捷键改一下,结果半天也没找到,改STRETCH找了好久才找到,太累了,看样子只有习惯一下默认的快捷键了。
[此贴子已经被作者于2007-3-16 14:46:05编辑过]
发表于 2007-3-17 01:01:00 | 显示全部楼层
确实有点不习惯,还是花点时间改一下的好!
发表于 2007-3-22 19:36:00 | 显示全部楼层
STRETCH的快捷键具体怎么改望能具体指点一下,以前没改过不清楚怎么改[em04]
发表于 2007-3-22 19:55:00 | 显示全部楼层
选择快捷键,要怎么样才能修改?????
[em05][em05][em05]
GMT+8, 2024-10-4 13:26 , Processed in 0.122976 second(s), 19 queries .
