查看: 455|回复: 3
pads2005 net报错
发表于 2007-6-6 11:33:00 | 显示全部楼层 |阅读模式
 pads2005  net报错
我有个原理图是protel转过去的,转时没有错误。
可是在生成PCB时却出现了下面的提示:
*Not valid pin name for part type B15
JP1.1 C1.2 P1.B15 P1.B3 P1.B17  (这些是连到GND的)
这是怎么一回事呢?
部分错误提示:
Part name already used J5
J5      HEADER_7X2@HDR2X7
Part name already used C190
C190    CAP_NP@0603
Part name already used C191
C191    CAP_NP@0603
*Not valid pin name for part type B22
P1.B22 P1.B28 P1.B34 P1.B38 P1.B46
*Not valid pin name for part type B49
P1.B49 P1.B57 P1.A18 P1.A24 P1.A30
*Not valid pin name for part type A35
P1.A35 P1.A37 P1.A42 P1.A48 P1.A56
*Not valid pin name for part type B9
C22.2 P1.B9 P1.B11 C23.1 C3.2
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MUTEC
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal GPIO57
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal AO_SD3
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal AO_SD2
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal AO_SD1
发表于 2007-6-6 15:36:00 | 显示全部楼层
软件已经提示你出错的地方了,修正它即可。无器件和pin定义找不到
发表于 2007-6-6 19:48:00 | 显示全部楼层
对啊!按提示的信息一个个改吧!
 楼主| 发表于 2007-6-7 16:30:00 | 显示全部楼层
那下面这些是不是不用改了,
C190    CAP_NP@0603
C191    CAP_NP@0603
GMT+8, 2024-10-3 23:23 , Processed in 0.137959 second(s), 19 queries .
