查看: 571|回复: 1
铺铜时出现了therm.err文件
发表于 2007-7-5 17:07:00 | 显示全部楼层 |阅读模式
各位高手我在第一层铺铜时出现了一个错误文件:therm.err,我看了一下thermal的设置,spoke的值是2, 并且大多数的过孔都是通地的过孔,请大家分析一下是出现这个错误文件的原因是什么呢?
文件内容如下:
Drilled pads with                    Nondrilled pads with
less than 50% thermal extensions      less than 50% thermal extensions
Report of Thermal Spokes Generator.
On Primary Component Side:
        (5150, 4100) # = 1
                                        D7/QFP.49 (3809.06, 1657.48) # = 1
                                        D2.45   (5248.03, 3988.31) # = 0
        (5175, 4000) # = 0
                                        D2.40   (5248.03, 4113.31) # = 1
                                        D2.34   (5248.03, 4263.31) # = 1
        (5325, 4275) # = 0
                                        D2.4    (5625.98, 3988.31) # = 1
        (5550, 3950) # = 0
                                        D2.1    (5625.98, 3913.31) # = 0
                                        B5.3    (4683, 3950) # = 1
                                        B15.3   (4233, 2900) # = 1
                                        N2.14   (2832.5, 3527.5) # = 0
                                        D4.16   (5562.96, 2784.11) # = 0
                                        D6.48   (5377.03, 1885.85) # = 0
                                        D6.45   (5377.03, 1810.85) # = 1
        (5450, 1850) # = 0
        (4825, 1825) # = 0
                                        D6.1    (4999.08, 1885.85) # = 1
Total Drilled pads:    6               Total Nondrilled pads:   13
Report of Violating Thermal Spokes Remover.
N8.9    (3967.72, 397.64) # = 1
                                        D6.4    (4999.08, 1810.85) # = 0
                                        D6.10   (4999.08, 1660.85) # = 0
                                        D6.12   (4999.08, 1610.85) # = 0
                                        D6.15   (4999.08, 1535.85) # = 0
                                        D6.21   (4999.08, 1385.85) # = 0
                                        D6.28   (5377.03, 1385.85) # = 0
                                        D6.34   (5377.03, 1535.85) # = 0
                                        D6.39   (5377.03, 1660.85) # = 0
                                        D6.45   (5377.03, 1810.85) # = 0
                                        N2.1    (2627.5, 3577.5) # = 1
                                        N5.2    (1899.62, 2252.18) # = 0
                                        D2.4    (5625.98, 3988.31) # = 0
                                        D2.10   (5625.98, 4138.31) # = 0
                                        D2.15   (5625.98, 4263.31) # = 0
                                        D2.21   (5625.98, 4413.31) # = 0
                                        D2.28   (5248.03, 4413.31) # = 0
                                        D2.34   (5248.03, 4263.31) # = 0
                                        D7/QFP.49 (3809.06, 1657.48) # = 0
        (5140, 4410) # = 1
        (5710, 4160) # = 1
        (2350, 2940) # = 1
        (5350, 1925) # = 1
        (5750, 4425) # = 1
Total Drilled pads:    6               Total Nondrilled pads:   18
      Drilled pads with
发表于 2007-7-5 18:29:00 | 显示全部楼层
不用管他
GMT+8, 2024-10-3 19:19 , Processed in 0.125646 second(s), 19 queries .
