ATCH NOTIFICATIONS ============ Title: Patch Notification for PADS2007 Update 2 Product: DxDesigner; DxDesigner-PADS; HyperLynx; PADS Layout; PADS Logic; PADS Router; ePlanner TechNote ID: mg79488 http://supportnet.mentor.com/snpe?tn=mg79488&snw_source=pro
Patch Notification for PADS2007 Update 2Symptoms- Patch Notification for PADS2007 Update 2
- Where can you download the PADS2007 Update 2 patch?
- Where can you download the latest PADS2007 patch?
TechNote TypePatch TechNote ProductsPADS Router PADS Logic PADS Layout Environment- PADS2007 Update 2
- Windows
- 2000, XP
- Mentor Standard Licensing Version: v2005_1
SolutionDistribution: Web: The PADS2007 Update 2 patch release is available for immediate download at: http://supportnet.mentor.com/downloads/062207.cfm CD: Not available
PADS2007 Update 2 was released on July 2, 2007. The following products are affected by the patch: - PADS Logic
- PADS Layout
- PADS Router
- PADS Suites
Note: PADS2007 Update 2 contains all fixes included in Update 1. The Update 2 patch should be installed by all PADS2007 users with the products listed above.
[此贴子已经被作者于2007-7-23 13:22:41编辑过] |
