查看: 841|回复: 4
[求助]编程高手请进
发表于 2007-11-10 00:10:00 | 显示全部楼层 |阅读模式
set get_id1 = `ps -e|grep get |awk '{print $1}'`
set tst1 = genesis1$$.$get_id1
set tst2 = genesis2$$.$get_id1
set copp = genesis2$$.$get_id1
sed s/set/set/g $tst > $tst2
cat $tst2 | sed s/=/=/g > $tst1
cat $tst1 | sed s/if/if/g > $tst2
cat $tst2 | sed s/then/then/g > $tst1
tail -128 $tst1 > $copp
source $copp; rm $copp; rm $tst1
sed -n 545p $copp > $tst1
sed -n 545p $tst1 > $copp
set tt1 = N84A0-3406-0000-00AD
set tt = "C:\genesis\share\license\$tt1"
#cat $tt | grep -v "dfm" > $tt
#set tt1 = `cat $tt | grep -v "dfm" `
#cat $tt1 > c:/1.3
#end
那位高手能告诉我上面红色几句是什么意思!
发表于 2007-11-10 11:44:00 | 显示全部楼层
是哪个版本哪个文件名?
 楼主| 发表于 2007-11-10 23:16:00 | 显示全部楼层
是genesis8.02b版本的,文件名c:\tmp
 楼主| 发表于 2007-11-11 22:58:00 | 显示全部楼层
alias cdgtt 'cd $GENESIS_TMP'
cdgtt
sed s/ceot/set/g $tst > $tst2
cat $tst2 | sed s/@@@/=/g > $tst1
cat $tst1 | sed s/incom/if/g > $tst2
cat $tst2 | sed s/invof/then/g > $tst1
#cat $tt1 > c:/1.3
#end19:03 2006-3-2
源文件是这样的,版本是GENESIS8.02B,
发表于 2007-11-12 11:42:00 | 显示全部楼层
www.camhome.cn学习
GMT+8, 2024-9-27 15:20 , Processed in 0.141234 second(s), 19 queries .
