查看: 2989|回复: 12
Genesis2000 9.02b 如何设置打印???? 急
发表于 2007-11-28 09:36:00 | 显示全部楼层 |阅读模式
 我刚装上Genesis2000 9.02b .听说他有打印的功能~~~ 就是不知道怎么可以设置好完整的打印功能!!!!
有那位高手能帮助一下! 在此谢了!!!
发表于 2007-11-28 10:40:00 | 显示全部楼层
应该是修改:/genesis/sys/hooks/lp_prog 文件才对吧?那么,"lp_prog.config"这个文件又如何配置呢?
34楼
mizuno 发表于:2005-8-20 16:28:12
QUOTE:
以下是引用pcb2worker在2005-4-29 20:21:29的发言:
看来还真没有人会啦!!!
我會............. lp_prog設定 set Platform = `uname` set PID = "$$" if ($Platform == "HP-UX") then set _GUI = $GENESIS_DIR/$GENESIS_EDIR/all/gui else set _GUI = gui endif # # 印表機選擇介面 # echo "WIN 200 200" > $GENESIS_TMP/PrintName.$PID echo "LABEL Please choose one to print ?" >> $GENESIS_TMP/PrintName.$PID echo "RADIO Printer Printer H 1 009900" >> $GENESIS_TMP/PrintName.$PID echo "HP-5000" >> $GENESIS_TMP/PrintName.$PID echo "HP-4050" >> $GENESIS_TMP/PrintName.$PID if ($Platform == "HP-UX") then echo "CAM HP-5000" >> $GENESIS_TMP/PrintName.$PID endif echo "END" >> $GENESIS_TMP/PrintName.$PID $_GUI < $GENESIS_TMP/PrintName.$PID > $GENESIS_TMP/ChoosePrintName.$PID source $GENESIS_TMP/ChoosePrintName.$PID rm $GENESIS_TMP/PrintName.$PID $GENESIS_TMP/ChoosePrintName.$PID #echo === $Printer === if ($Printer == 1) then set PrinterName = "hpLJ5000-DE" set HPPrinterName = "hp5000" else if ($Printer == 2) then set PrinterName = "hpLJ4050-DE" set HPPrinterName = "hp4050" else set PrinterName = "hpLJ5000-DE" set HPPrinterName = "camhp5000" endif # # 列印 # echo === $Platform === if ($Platform == WINDOWS_NT) then # echo === $PrinterName === echo $2 c:/usr/local/bin/sed.exe s/"Frontline"/"Mizuno"/g $2 > $GENESIS_TMP/ps-tmp.$PID c:/usr/local/bin/sed.exe s/"http:\/\/www.frontline-pcb.com"/"http:\/\/www.pcbsky.com/"/g $GENESIS_TMP/ps-tmp.$PID > $2 net use lpt2: "\\bdc\$PrinterName" cp $2 lpt2: net use /delete lpt2: rm $2 $GENESIS_TMP/ps-tmp.$PID else echo $2 sed s/"Frontline"/"Gold Circuit Ltd."/g $2 > /tmp/ps-tmp.$PID sed s/"http:\/\/www.frontline-pcb.com"/"http:\/\/http://www.pcbsky.com/"/g /tmp/ps-tmp.$PID > $2 /usr/bin/lp -d $HPPrinterName -c -n $1 $2 rm $2 /tmp/ps-tmp.$PID endif
发表于 2007-11-28 10:49:00 | 显示全部楼层
从别处找来了!看不懂!还请高手帮忙看看!
 楼主| 发表于 2007-11-30 08:00:00 | 显示全部楼层
难道没有人知道这个问题吗?
发表于 2007-12-2 08:06:00 | 显示全部楼层
有就是要=高手吧··
我也不会用··
一起=吧··
[em01][em01][em01]
发表于 2007-12-2 10:06:00 | 显示全部楼层
我会,找我
 楼主| 发表于 2007-12-2 10:54:00 | 显示全部楼层
楼上的高手~  如何联系你啊? 用QQ. windows
 楼主| 发表于 2007-12-3 18:24:00 | 显示全部楼层
坚持到底~~ 自己顶一下!
发表于 2007-12-22 13:27:00 | 显示全部楼层
我猜的 以前我们公司用的是xp系统  有网络打印机也打不出来的。。现在公司是liunx系统。。工作站打印,。。
   现在也没时间想了。。。。 是不是要奥宝开通功能哦!!!!!
发表于 2007-12-22 14:04:00 | 显示全部楼层
我的可以打印
GMT+8, 2024-9-27 19:25 , Processed in 0.232626 second(s), 19 queries .
