查看: 1424|回复: 3
ECO怎么没有记录
发表于 2008-6-13 12:32:00 | 显示全部楼层 |阅读模式
如下的ECO。我改了几个元件的封装,怎么ECO文件里面没有记录?谢谢!
** ECO In Report **
Fri Jun 13 12:27:11 2008
Input  File : D:\Program Files\PADS Projects\eco2pcb.eco
Current Job : Untitled
Line 14 , Section *DEL_ATTRIBUTE*
"Comment"
* WARNING: Processing command to delete attribute "Comment" from Component UU1.
*          The attribute is also inherited from Decal QFN5X5-32.
*          The change is not fully reconciled for cases where the schematic
*          does not support hierarchical attributes.
 楼主| 发表于 2008-6-14 09:01:00 | 显示全部楼层
谢谢,自己顶一下!
 楼主| 发表于 2008-6-14 09:46:00 | 显示全部楼层
今天又试一试了,发现ECO的这个eco.err记事本文件里面怎么还是没有我修改和增添了的元件的ECO记录?如下内容:
** ECO In Report **
Sat Jun 14 09:43:55 2008
No errors found
Attribute Dictionary was modified during import operations.?The following
attributes were added to the Attribute Dictionary as non-ECO Registered:
Sim.Analog.Model
Sim.Analog.Order
Sim.Analog.Prefix
Part Number
Manufacturer #1
Voltage Rating
 楼主| 发表于 2008-6-14 15:20:00 | 显示全部楼层
再顶一下!
GMT+8, 2024-10-2 01:22 , Processed in 0.141674 second(s), 19 queries .
