查看: 2697|回复: 9
ORCAD CAPTURE输出网表导入PADS LAYOUT的问题
发表于 2008-8-14 17:34:00 | 显示全部楼层 |阅读模式
用ORCAD CAPTURE CIS 10.5导出asc格式的网络表(如下图),出现如下问题,是什么原因呢?Unspecified or unsupported version of ASCII file是什么意思呢?怎样解决??
Reading file --  C:\Documents and Settings\Administrator\桌面\PERIPHERY.asc
*Unspecified or unsupported version of ASCII file
*PADS-PCB*
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPC0
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPA16
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPA13
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPA15
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPA12
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPC6
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPC7
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CONN/GPC5
Warning: deleting signal CONN/GPC0
Warning: deleting signal CONN/GPA16
Warning: deleting signal CONN/GPA13
Warning: deleting signal CONN/GPA15
Warning: deleting signal CONN/GPA12
Warning: deleting signal CONN/GPC6
Warning: deleting signal CONN/GPC7
Warning: deleting signal CONN/GPC5
**INPUT WARNINGS FOUND**
 楼主| 发表于 2008-8-14 17:37:00 | 显示全部楼层
好像很多人都有遇到这种问题,但是网上找不到解决方法。。。
 楼主| 发表于 2008-8-15 09:03:00 | 显示全部楼层
没人在吗??
发表于 2008-8-15 09:54:00 | 显示全部楼层
可能是你的那几个原理图管脚设置的属性不对 设置成passive 试一试
发表于 2008-8-15 10:59:00 | 显示全部楼层
导网表前你有没有做DRC检测??
要检查没问题再导试下
发表于 2008-8-15 16:07:00 | 显示全部楼层
你要把.asc文件头换一下,
这是Orcad产生的文件头:*PADS2000*
换成:!PADS-POWERPCB-V2005.2-MILS-CP936! NETLIST FILE FROM PADS LOGIC V2005.2
 楼主| 发表于 2008-8-20 17:49:00 | 显示全部楼层
6楼的朋友能不能说详细一点呢?不太明白
发表于 2008-9-3 22:13:00 | 显示全部楼层
导网表前你有没有做DRC检测
2 表示 CONN/GPC0 NET線...  沒有 連接 其他零件 只有單點
[em09][em09][em09]
发表于 2008-10-7 19:44:00 | 显示全部楼层
[em01][em01]
发表于 2008-10-10 17:52:00 | 显示全部楼层
在没有用的脚上放个 X 就可以了,表上忽略这问题。再导就可以了
GMT+8, 2024-10-1 10:39 , Processed in 0.135072 second(s), 20 queries .
