- 2882
发表于 2003-4-14 18:15:00
显示全部楼层
以下是引用gowan在2003-4-7 13:03:30的发言:
它们都有“传感器”的意思,既然是两个词,总该有些区别才对。
这都是在金山糍粑上看的,有兴趣就参考下吧
transducer
变换器,换能器;传感器
A device for converting energy form one form to another. In relation to computers, the term is applied to a read/write head, to detector of sector marks in a magnetic disc system, and to electronic/sonic pulse converters of delay line memory.
把能量从一种形式转换成另一种形式的装置。在与计算机有关时,这个术语用在磁盘系统中的读/写磁头、扇面标记的检测上,以及用在延迟线存储器的电子或声波脉冲变换器上。
transducer
A substance or device, such as a piezoelectric crystal, microphone, or photoelectric cell, that converts input energy of one form into output energy of another.
换能器一种能把输入能量转化为另一种输出能量的物质或装置,比如压电晶体、扩音器或光遇管
sensor
传感[检测]器;[感测器]
A device that converts measurable elements of a physical process into data meaningful to computer.
一种器件,将物理过程中的可测量转换成对计算机有意义的数据。
sensor
n.
传感器; 感受[敏感]器
敏感元件[装置]
接触元件
探测器[设备]
初级检测器
仿形器
sensor
A device, such as a photoelectric cell, that receives and responds to a signal or stimulus.
传感器接收信号或刺激并反应的器件,例如光电池
[em05][em05] |
