查看: 2603|回复: 14
英语太差!
发表于 2003-4-8 00:06:00 | 显示全部楼层 |阅读模式
发表于 2003-4-9 16:19:00 | 显示全部楼层
Rome is not built in a day.The best way to learn english is to read english as many as possible.
 楼主| 发表于 2003-4-9 19:24:00 | 显示全部楼层
我知道要持之以恒,但是我感觉我的方法不是对的!因为我想如果自己的方法对的话,只会是越学越想学,在其中找到了乐趣!但是我现在还没有在里面找到任何乐趣,你说这怎么办呢 ?
发表于 2003-4-10 13:10:00 | 显示全部楼层
我对英语一占都不懂。
我应该从哪开始学?
发表于 2003-4-10 17:36:00 | 显示全部楼层
Everyday you should  listen to english for some time.Maybe at the beginning you couldn't concentrate on it,you should force youself to listen to it.step by step you would like listening to english.I think to learn english well,we should read loudly everyday.I like reading english loudly.from reading we can find the interesting .
I am crazy about liyangcrazyenglish.I think it is useful to me,maybe you can try it too.I hope one day you all can speak english fluently.
 楼主| 发表于 2003-4-11 13:34:00 | 显示全部楼层
谢谢你给了我那么多的建议!我想在问一下李阳的疯狂英语选用那种的好呢?因为他的版本太多了!还有就是我的英语词汇不是很多,因为我很难把他记得,你说如何才能把它记好记牢呢?还有在大声朗读的时候是想着他的汉语意思还是怎么才最好呢?请指教!
发表于 2003-4-11 17:10:00 | 显示全部楼层
A me(i) li a~~~
you are right ~~~
The way is good ,I will do it,Read aloud ~~~is absolutely good habit.Thank you ~~
发表于 2003-4-11 17:11:00 | 显示全部楼层
我也有同感
发表于 2003-4-11 17:28:00 | 显示全部楼层
Yes,there are many versions.When you buy,you should choose what is fit for yourself now.I think you would benefit nothing from books until you use them.Once I liked buying books especially english books and never read them.I find it is common among us.so when you got a book,you should use it.If not,you got nothing.sometime it is better to borrow books from your friends.
At the beginning,when you read english,you need pay more attention on pronounciation not on the meaning i think.but every one has his own way.you could try what I had said and find your own way.
Yes,vocabulary is a headache.but there is no quick solution to it.it is a process.all of us should spend some time on it.
after grasping the basic grammar and having a basic vocabulary,we should turn to our pronounciation.
 楼主| 发表于 2003-4-11 18:16:00 | 显示全部楼层
谢谢,谢谢你给我的方法!我会尽力按你的方法去做,希望早日能提高!
GMT+8, 2024-9-21 22:19 , Processed in 0.129998 second(s), 20 queries .
