我的也一样,没有破解成功, 第一次,好象是成功了,但是安装目录不理想,很乱,所以又卸了,又重新安装,1次、2次、……、n次,还是不成功, 现在又重新安装了系统,专门安装它,但是很失望…… 我是按照这种方法做的: Install the License Manager. When asked for License File Location, CANCEL that dialog. Copy cdslmd.exe to C:\Cadence\LicenseManager (or wherever you installed it) and overwrite. Run LicenseServerConfiguration.exe and use the included license.dat. Answer YES when you get a message about the host name validity. "View Log" to make sure everything is running ok. Done. Install the application Skip the CONTROLEFILE.TXT dialog. Installer will ask for data3.cab on \Disk2, browse to your CDROM instead (buggy installer!) When asked, write 21000@localhost in the License Path box. Put the tbe-patcher.exe in <install dir>\OrCAD_16.2 and run it. Give it a minute to finish, enjoy the music while waiting... Done. |
