1.Edit the license.dat file, replace this_host as your computer name, don't change any other data. 2.Install license server. 3.When the computer asks you to point to the license.dat, copy the edited license.dat file to folder X:\Cadence\license_manager and ponit to this file. 4.After installation license server, the environment parameter CD_LIC_File was set up by the computer automatically. 5.Install Allegro. 6.Copy shooters.exe to foler X:\Cadence. Run it. 7.If shooters.exe could not run well by the way in 6, please select "start->run", enter "cmd" and press return, then a dos command dialog pops up, then come to the folder X:\cadence, run shooters.exe under this environment. 8. Restart the computer, enjoy spb162. 这个就是shooter破解方法,我照着这个安装成功过。 但是有个问题我没有解决啊,提醒你一下,按照这种方法安装后的软件当点击卸载以后还是启动的安装程序,导致无法卸载16.2。 我试过同时安转15.7和16.2,但是没有成功。总是有一些功能是相互冲突的,原来我一直用的15.7,其实16.2如果把openGL关掉以后和15.7感觉上是差不多的。如果你做的项目里HDI的东西不是特别多的话,15.7就可以了。 两个版本不是互相兼容的。 那个删起来很麻烦! 也可能是我安转的方法有问题? 高人指点一下。 |
