第一次用PADS,别人给的PCB,但是没有原理图,只有原理图PDF,所以我照着PDF画的原理图,在导入后出现如下问题,待解决: Reading file -- D:\pro\BMP0101-01\SMARTCARD\01-14\zzz.asc *Unspecified or unsupported version of ASCII file *PADS-PCB* Part name already used C1 C1 CE-0.2 Can't find part Type item < SO28W > IC1 SO28W Can't find part Type item < L10 > L1 L10 Can't find part Type item < L10 > L2 L10 Can't find part Type item < SOT-23 > Q1 SOT-23 *Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N2854659 Mixing nets 3V3 C1 1 NETR5_1 R5 1 IC1.21 R1.1 R8.2 R3.1 C3.1 L1.2 C1.1 R5.1 Mixing nets N2854835 R2 2 NETR2_2 R2 2 R2.2 IC1.2 *Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N2854835 Mixing nets N2855061 R3 2 NETR3_2 R3 2 R3.2 IC1.3 *Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal X00027 Mixing nets N2886049 Q1 1 NETR10_2 Q1 1 我看了最后一个ERROR,原理图上的名字是 N2886049,而PCB上的名字是NETR10_2 不知问题出在哪,PCB库也已经保存在默认目录下了,望指教。
