查看: 1130|回复: 2
genesis v8.0a安装手册
发表于 2006-2-14 15:43:00 | 显示全部楼层 |阅读模式
The GENESIS 2000 v8.0a only runs on WinNT 4.0/ Windows 2000 Operating Systems.
01. Extract all split files using WinRAR.
02. Write the BIN + CUE file using CDRWin or any cd writing software you preffer that supports BIN image.
03. Insert the cdrom to the drive and it should start the installation automatically.
    If you extract the BIN file to your hard drive then run the INSTALL.BAT to start the setup.
04. Select installation source from cdrom, type in the cdrom drive label and root directory, ex. "E:/"
05. Select the product/version/platform you want to install, ex "app_gen/v80a/nt"
06. Click on "load install plugin"
07. Type the install destination directory, ex "c:/genesis"
08. Click "start" bottom.
09. In 3rd step "setup start up files" the program will ask you for the installation serial, use "sx0397b10011"
10. In step 4 "setup license", you need to locate the provided cracked license file.
11. After installation, don't reboot the machine, copy the cracked gnd.exe to installed directory and replace
    the orignial one. ex "c:\genesis\e80\gnd\gnd.exe".
12. Reboot the machine, run get.exe in c:\genesis\e80\get\, that's all!
* Users that dont have Vision Server installed on their system then make sure to install the Vision Server
  (Nutcracker). You'll be propmt if you would like to install  Vision, click YES. Before running Valor
  Genesis 2000, you have to enable Vision Communications by click on START + SETTINGS + CONTROL PANEL and
  you'll see the icon named VISION COMMUNICATIONS from the control panel, open it and from the TABS
  options click on TRANSPORT and double click the TCP-Unix, from the Availability Status options, select
  the "Enable this transport and click APPLY and OK.
  Enjoy from EFA TEAM !!!!
发表于 2006-2-19 15:49:00 | 显示全部楼层
谢谢
发表于 2006-3-19 20:09:00 | 显示全部楼层
学习中
GMT+8, 2024-9-22 09:39 , Processed in 0.119797 second(s), 19 queries .
