我现在再用POWERLOGIC软件导网络表,可是出现了3个报错信息,我是POWERPCB新手,第一次画原理图,麻烦版主尽快回复!THANKS 1.Line 99 , Section *PART* C16 CT * Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "KR-1206-01P". Open Layer Setup dialog box and change the layer mode of the design to increased layers. 2.Line 145 , Section *NET* CT129.1 U30.6 * Part name CT129 not found 3.Line 886 , Section *SET_ATTRIBUTE* *SET_ATTRIBUTE* PART CT7 * Incorrect object name : CT7 [em06][em06] |
